Abuchanan91
I was driving my 2016 gt the other day and lost all cutch pedal. Still had enough pressure to return to the top but not the engage shift forks. Found a wet spot on my floor mat under the clutch pedal so I assume it's the clutch master cylinder.
I replaced the master cylinder and can't get the clutch pedal to pump back up. I have pumped it for hours, I filled the brake master cylinder up, I put it under vacuum, and I pumped some more, I repeated the vacuum/pumping like Ford recommends, still no luck .. I honestly don't know what else to do..
Has anyone experienced this issue and if so how did you fix it? Could it be a multi part failure like the slave went out too or maybe a pressure plate issue??
I really don't want to drop the tranny if I can avoid it.. Please help
