Clunk/tumbling/knocking felt in the pedal when accelerating
Nagare
Ft Lauderdale
2017 Lightning Blue V6
Wondering if anyone might be able to suggest what this is. I've had my X4 hooked up and it doesn't seem to be engine knock based on that.
After a 2 hour each way road trip this weekend, I noticed a weird tumbling or knocking sound that I felt in my gas pedal as well. It was brief and I couldn't figure out what was causing it. Happened again earlier today and seemed like it may have been around 1-2k RPMs in first or second gear. I'm stumped because it was just at low speed starting to accelerate and I can't seem to replicate the issue.
Any ideas? I haven't really noticed any additional noises going over bumps or unsmooth sections of road either.
USMCtoARMY
Lake Stevens, WA
2016 Mustang V6 MT
If you can get a recording. Its just a knock and tumble? There isnt any "slip" feeling in the clutch or feeling a loss of "power" right? Did it start just recently after you had your new exhaust welded in?
Nagare
Nagare
Ft Lauderdale
It felt like something was loose and knocking around to me at first but I couldn't find anything and I haven't noticed any lose of power.
No strange exhaust noises either.
Automatic car btw so can't answer clutch slip.
If I can get it to happen again I'll try and get a video.
Nagare
Nagare
Ft Lauderdale
https://photos.app.goo.gl/GrEHdKbf2S66GcdK6
Took this on my drive to work today. Sound only happened at the 3:30 mark but can't edit anything until I get home. The other times it happened it was a few times in a row instead of just once like this time. IIRC it was while I was accelerating into the curve of the on ramp. Not sure if this is something engine or suspension related, but figured I'd start in here.
USMCtoARMY
Lake Stevens, WA
2016 Mustang V6 MT
It's hard to tell in the video if what I am hearing is what u are...its sounded like a rattle during acceleration. Nothing to do with trans. Is your AC on? Being that it recently showed up after u had work done it's more than likely related to the work.
Is that a premium bezel I see with V6 push start?
Nagare
Nagare
Ft Lauderdale
3:20 - start accelerating
3:23 - turn signal on
3:27 - bump in road
3:29 - turn signal off
3:30/3:31 - the noise
The background noise you hear on acceleration is exhaust hitting the cat delete pipes, exhaust, and tire noise. When I picked it up around the 4 minute mark was to make sure on where I heard the sound.
AC and radio off.
Yes its a premium bezel, did a Sync 3 swap a few months back now.
cyclonetron
Tennessee
Patrick
2016 Mustang v6
Do you have a oil catch can? If so I had some rattling going on due to the canister vibrating against a line. I twisted the canister a bit so that it wasn’t touching the line.
Nagare
Nagare
Ft Lauderdale
No catch can yet.
Got it up in a lift at the exhaust shop with them just to make sure and nothing looks obviously loose it hanging.
Further "testing" around the plaza gets it if I accelerate through left turns. Guy that also drive it said it felt something was pulling to him.
Nagare
Nagare
Ft Lauderdale
Here's a video with the issue:
5-7 second mark and 53-54 seconds
MidwayJ
Dallas, Texas
Jay
2019 Mustang GT Coupe
Weird. It sounds like somebody just dropping something in the interior of your car. It it more likely to happen during hard turns? Could something be shifting from lateral g forces?
Nagare
Nagare
Ft Lauderdale
Not trying any turns too hard while it's happening that's for sure! Don't want it to really cause a problem that I won't be able to fix as easily.
USMCtoARMY
Lake Stevens, WA
2016 Mustang V6 MT
It's just hard to tell on the video but since your hearing it on turns its got to be in your front suspension, UNLESS its something coming into contact with your frame thats loose and only hits when u turn.
Nagare
Nagare
Ft Lauderdale
I'm happy to report back that it was something a little loose. Exhaust piping was hitting the trans mount. Used a bar to move it a bit further away and tightened up the clamp a little bit (got a half turn) and it seems to be gone for now.
USMCtoARMY
Lake Stevens, WA
2016 Mustang V6 MT
Lol, I told ya I thought it was something from you having exhaust work! Glad its squared away and the stress is gone bro.
