Performance nut
Is anyone using an APR chin splitter? If so, what wing (if any) are you using in the back?
Reason I ask is because I got a really weird response from APR about the GTC-200 wing.
So the GTC-200 wing fits our car and it is about the same height as the GT350 spoiler. The CFD they performed may change based on the car's design, probably not a huge amount but I can see it may be changed. But the part that you distinguish between a drag wing and a track wing has me confused.
Downforce is downforce. The only thing I don't know is how much downforce our cars need at what speeds to have better traction on a road course. Based on that, you could select the right wing and AOA. Usually this is trial and error but usually there is that guy who knows these things.
The front splitter is to get rid of the lift I feel at speed but I don't want to induce an unbalanced downforce by only adding the splitter without a wing. Personally I don't like the GT-250 because it is just huge and my car is not a dedicated track car. At the same time, I don't want to induce significant oversteer in my car by adding too much downforce in the front without countering it with rear downforce.
As far as the proper GT wing and splitter setup for this car it is the GT-250 spec wing. the GTC-Drag is not designed for the vehicle and the downforce data on our site is not applied to this wing. this wing only has 3 adjustments and is what it is labeled as a Drag wing. the GT-250 is a Track Wing this is designed to sit in the correct locations for proper function and downforce. The wing comes with all necessary hardware for proper installation.
