So the check engine light didnt turn on anymore, but today i pulled from 3rd gear and the check engine light started flashing and the car felt like boost was not hitting it and i shifted into 4th and the boost hit. I did the pull on track mode.
I think it might have been the tune. I got a new tune a few weeks ago because of surging and now i went back to the old tune and nothing happened boost went in fine 2nd,3rd and into 4th
Sad to say i was in 3rd again and at 5 punds the boost stopped and check engine light turned on. Could this be cause by boost leak or bad sparkplugs? Im still running the stock plugs.
I had the misfire at about 5500 rpm and it was just the plugs getting "blown out" was what I was told. Went with NGK and it corrected the misfire at high rpm.
The car didn't drive worth a shit until I got a Lund tune.
Having the same issues after installing Paxton with there preloaded tune. I got codes P2006 & P2007 (IMRC's being stuck closed) The vacuum port was pinched going to the valves that control them, but I found it early on and fixed the lines. Iv'e cleared the codes numerous times and the light keeps popping on even after the fix. Doesn't seem to drive abnormal. Anybody have any information regarding this?
