Changing Nav Volume?
AustinM77
Toronto
2017 Ecoboost Premium
Not sure if I'm just blind but I'm pretty sure I went through all the menus trying to turn the nav volume up. When I'm listening to music at decent volume (15ish) the turn by turn directions come over top at basically a whisper. Anyway to change this or do I have to crank the volume every time I want to hear the directions?
angermgmt14
Massachusetts
2016 GT Premium--Oxford White--A6
I had the same issue when I disconnecting the negative cable to install my GT350R wheel. I couldn't find/remember where the setting was, so when the Nav. starting speaking I just turned it up to my liking. It has stayed at that level going forward.
Gigantor
Arizona
Wes
2016 Ford Mustang GT Premium
Adjust volume whenever the Navigation speaks, using the volume control on the steering wheel
UofMEngineer
Michigan
22' FE, 20' FE
This. Also applies to other "sources" like system and voice prompts. Adjust volume as they are read out.
AustinM77
Toronto
Little bit late but thank you both. Feeling really dumb after searching for a solid 20 minutes in the menus but it never hit me to do this.
