69mach1-395
- Dec 4, 2014
- central nm, usa
- 2016 RR GT/CS
Sounds easy enough, but I can't get the passenger side hose retainer off without possibly breaking it. Even a video show it being done with the entire assy removed...It's most likely going to be that same valve. Disconnect the hose from it and the power connector. Then start your car. If you feel suction on the part where the tube was connected then the valve is stuck open. (It should not be open unless the power plug is connected to it). Real simple easy test
What's the trick with it still attached to the engine?
