cat deletes and tune?
vanquishvzla
Jacksonville - FL
2015 Mustang GT 50th anniversary
quick noob question... installing cat deletes, do i have to tune the car? will the canned tune for LT headers on the sct x4 work?
the reason why i ask is because i want to pull the trigger on the cat deletes right away... i'm buying a flex tune from PBD to pair with the new +18 IM, injectors, blah blah blah... so, do i have to tune? if i have to... can i use the canned one? or will be better if i do the IM swap and then do the deletes? the new tune will have the deletes as part of my mods...
RacinJason
Mississippi
2017 Mustang base GT w/PP
Do all the mods and let PBD tune for them. Datalog and work with them to get it tuned right. Don't load a canned tune and cut the cats. Not worth risking a solid tune that PBD will give you. Patience.
vanquishvzla
vanquishvzla
Jacksonville - FL
the PBD tune will be at the end... the reason why i'm asking is because one shop is going to do the cat deletes and then i have to drive the car to the shop doing the IM swap... i was planing on doing it myself but i'm being lazy and i don't feel like spending half sunday (only day off) working on that
Stephen@lethal
2020 Mustang Gt500
You will need to get a new tune for the cat without cats unfortunately. But the plus side is you will gain good power with the new tune. Hit me up if you would like to see what we can do for you on a tune. We have a PBD sale coming up here very soon. Lethalperformance.com
vanquishvzla
vanquishvzla
Jacksonville - FL
i'm buying the tune from you guys... when is the sale??
right now i only have the canned tune from the sct x4 with the jlt cai option... the question was if i can use the same canned tune but adding the LT headers in order to work with the cat deletes... just because i have to drive the car from one shop to another...
when i buy the tune from PBD i'll never look back to the canned tunes lol...
Stephen@lethal
2020 Mustang Gt500
You will be able to run the tune to get it to the shop, but it won't run the best, I would limit how much you drive it and refrain from wot pulls until the new tune is on it. PBD should be going on sale first thing in April. Shoot me a PM if you need the tune sooner and I can see what we can do.
vanquishvzla
vanquishvzla
Jacksonville - FL
no rush... specially if is gonna save me some money lol
crcpdx
Charlie
I had an E 85 tune with PBD and when I installed my cat deletes, Trevor told me I did not need a new tune.I even sent him some logs to be sure. IDK anything about these canned tunes, but I'd suspect you would be fine running it. As Lethal stated I wouldn't be doing 60 to 130 rolls,but the car is not going to be hurt from normal driving.
FruityJudy
South Alabama
2018 Mustang GT A10
Idk why you couldnt go ahead and get the full setup tune, load it, drive it easy to the exhaust shop, then drive to the IM shop, leave the IM shop and start datalogging
AZ18yote
Arizona
Bryan
Get the real tune. I would never use a canned tune on the device. The device is simply the vessel to load a tune.
vanquishvzla
vanquishvzla
Jacksonville - FL
i needed something to run the POS JLT cai lol... i wish i kept the araid tube with the k&n drop in filter
illtal
Canned Tune will not turn off the CEL. You will have to specify that with your tuner.
Honestly If you are N/A and you do a Cat delete you will probably only have the CEL unless you buy the J Extenders to make the rears read right.
But If i was you i'd wait and install when you get the flex tune. When you change something like an intake tube size it changes the metering which is why you need a tune to make it run right
