Yea i’ve done that but I bought an automatic daily driver for a reason - don’t want to have to downshift with paddles every day - should only have to use them when I WANT to, not because I have to.Have to tried using the downshift paddle to get a quick downshift in the situation you described? If you are in D normal the trans will automatically revert to automatic mode about 3 seconds after paddle use unless you are coasting with no gas.
Understood but mine and/or my driving style/"wants" does not have the problem. When I want more acceleration in normal situations I squeeze on more throttle and the trans downshifts the number of gears, if any, needed for the amount of throttle. Conversely full throttle from low speed absolutely gets my attention with downshifts and rapid acceleration. Whee!Yea i’ve done that but I bought an automatic daily driver for a reason - don’t want to have to downshift with paddles every day - should only have to use them when I WANT to, not because I have to.
It absolutely should not rev match in normal driving mode on the A10. I have a 2018 with A10 and when in normal driving mode it behaves like a normal car, as it should, but when you go to S+ or Track, it will rev match when you hit the brakes. It is very noticeable when you are going at higher speed and hit the brakes hard. I enjoy the rev matching, but can see how it would be annoying if you aren't a fan of it. Anyhow, if yours is rev matching in Normal or Snow/Track, or both, take it to the dealer. It shouldn't be doing that.high hp/high performance car or not, when in normal driving mode it should behave like a normal car. non of my other Mustangs, nor my Scat Pack, G8 GT or Camaro ever behaved abnormally in regular driving modes. to me in an auto trans equipped car it seems like some kind of Ricer gimmick. i don't need it or want it. can it be turned off?
yeah, sounds like a trip to the dealer is gonna have to happenIt absolutely should not rev match in normal driving mode on the A10. I have a 2018 with A10 and when in normal driving mode it behaves like a normal car, as it should, but when you go to S+ or Track, it will rev match when you hit the brakes. It is very noticeable when you are going at higher speed and hit the brakes hard. I enjoy the rev matching, but can see how it would be annoying if you aren't a fan of it. Anyhow, if yours is rev matching in Normal or Snow/Track, or both, take it to the dealer. It shouldn't be doing that.
"car" lolOut of curiosity what are the build dates of the cars with the problem?
Mine without the problem is 12/21.
the date at the bottom of my window sticker says 11/27/17, not sure if that's a build date though. my window sticker says not to be offered for sale and the car had to be held for a while once the dealer received itOut of curiosity what are the build dates of the cars with the problem?
Order Information:
Vehicle Name: 2018 Mustang GT Fastback
Ordered On: 10/09/2017
Order Number: 9000
Dealer Code: 74W501
VIN: 1FA6P8CF7J5123888
Dealer Name: Chuck Colvin Auto Center
Estimated Delivery: 12/27/2017
Current State: Delivered
In Order Processing: 12/05/2017
In Production: 12/05/2017
Awaiting Shipment: 12/08/2017
In Transit: 12/27/2017
Delivered: 12/27/2017
Source: [url]http://www.cotus.ford.com[/url]
ok so maybe it's not rev match but it is NOT engine braking. the car actually surges forward. I've owned many many performance cars in my life both modern and classic and this is NOT a normal thing. if you read the thread you'd note that i'm not the only one who complained of this. if it were engine compression braking the car would slow when the gears change and the RPM would increase to correspond with the vehicle speed.. NOT cause the vehicle to move forward with great momentum.Ok just to be clear your car is NOT rev matching, as that is a feature for manual trans only! What you are experiencing with the a10 in your car is engine braking. It is not able to be disabled nor is there anything wrong with the transmission it is simply doing what it is designed to do, which is downshift using the engine rpm to help assist you with braking.
Are you going to stop by the dealer about this?ok so maybe it's not rev match but it is NOT engine braking. the car actually surges forward. I've owned many many performance cars in my life both modern and classic and this is NOT a normal thing. if you read the thread you'd note that i'm not the only one who complained of this. if it were engine compression braking the car would slow when the gears change and the RPM would increase to correspond with the vehicle speed.. NOT cause the vehicle to move forward with great momentum.
I believe the pull you’re feeling is from the sudden jump in torque. But yea, I never once thought or felt this was engine braking occurring.ok so maybe it's not rev match but it is NOT engine braking. the car actually surges forward. I've owned many many performance cars in my life both modern and classic and this is NOT a normal thing. if you read the thread you'd note that i'm not the only one who complained of this. if it were engine compression braking the car would slow when the gears change and the RPM would increase to correspond with the vehicle speed.. NOT cause the vehicle to move forward with great momentum.
