Camber adjustment vs wheel poke
cjldad
Richmond, Va
2017 GT PP
I think I remember reading on here somewhere the math on how much a 1 degree change in camber changes wheel/tire poke on the front and rear?
Can someone refresh my mind please.. :)
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Something like a quarter inch of poke per 1 degree would be my estimate.
cjldad
Richmond, Va
2017 GT PP
So, I think I figured it out..
1/ ((tan (angle) / diameter))
So for 1 degree of negative camber it would be
tan (91) = -57.29
-57.29 / 27.7 (diameter of 305/30/20 tires) = -2.106
1/-2.106 = .4748 inches......
1 degree = -0.4748
1.2 = -0.5698
1.4 = -0.6647
1.6 = -0.7598
1.8 = -0.8548
2.0 = -0.9498
2.2 = -1.045
Looks like 0.47 per degree..
I think.. :)
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
Tire height is too much, since the tire can only pivot mechanically about either the ball joint (for the lateral link) or somewhere within the strut to knuckle attachment. It does not pivot about the contact patch.
I think you need to use the length measurement from the lateral ball joint's pivot height and the top of the tire if you're making camber adjustments at the strut top. This will be somewhat shorter than the tire diameter (5" to maybe 9" less), so the change in poke per degree of camber change would be a little less than you get using tire diameter directly.
For adjustments made at the strut to knuckle attachment, you'd use the difference in height between the center of the strut fastener that you don't use for adjusting and the top of the tire. If you were to adjust at both of the strut to knuckle fasteners, the midpoint between the two fasteners should be close enough. Any of these will be even less than the balljoint-based math.
27 * tan(1°) is 0.47" . . . basically half an inch (and too much)
Roughly for camber pivoting about the ball joint, 20 * tan(1°) is 0.35", around half that for adjustments made at the strut to knuckle attachment.
Norm
Norm Peterson
Norm
'08 GT #85, '19 WRX
Just meant to mention that I was guessing at the balljoint height. But an inch or so either way on the balljoint height isn't going to change the calcs much as far as visual appearance is concerned.
Norm
cjldad
Richmond, Va
2017 GT PP
That's right.. Also, I like your math better.. Much cleaner than mine..
Smart fella!
NightmareMoon
Yup, I was estimating closer to pivoting just below the center of the wheel (trying to guess at those suspension joint pivot points), thus the 1/4" instead of 1/2".
Grintch
Hunstville
2015 GT PP
And you thought you would never use Trig in real life.
