millhouse
- Jun 27, 2016
- Simpsonville SC
- 2016 Ruby Red GT PP
You apparently didn't read anything I wrote. The 1LE not only has a much more track ready tire compound, but the FRONT TIRES ON THE 1LE ARE WIDER THAN THE REAR TIRES ON THE PP1.I agree. But many here are saying the only reason the 1le beats the pp1 is because of the tires. I also believe the PP2 will be very close to the 1le, but believe the 1le will still be faster. Weight will be one reason, and imho, the chassis is still a little better for track.:cheers:
How does that strike you as glaringly obvious as to the intent of each vehicle?
And for the record, we have been saying all along that the PP2 will come not only with the better and wider wheels and tires, but will have a different tuned suspension to go along with it.
āItās highlighted by a lower stance, a redesigned front splitter and rear spoiler, and 305/30/R19 Michelin Pilot Sport Cup 2 tires wrapped around split-fitment aluminum wheels ā 19x10.5-inch front and 19x11-inch rear.
The tires, 1.5 inches wider than those found with Performance Pack Level 1, provide a firmer grip, and work with a retuned chassis to put the car more than a half-inch closer to the ground. The package is available exclusively with a manual transmission.
Custom tuned MagneRideĀ® dampers and quicker steering calibration provide better response. Other improvements over Performance Pack Level 1 equipment include a 67 percent stiffer rear stabilizer bar, a 12 percent stiffer front stabilizer bar, 20 percent stiffer front springs and rear springs that are 13 percent stiffer, all of which contribute to a more stable ride around corners with less body roll.ā
Again, it's not just tires.
You can read about other changes here..
http://performance.ford.com/enthusiasts/media-room/2017/10/mustang-gt-performance-pack-2.html
