Bov and a waste gate
chriseco
florida
2016 silver 6spd base ecoboost
My Eco boost is first turbo car iv ever had or even drove so forgive me for not knowing
I recently bought a bov and then learned that a bov and waste gate is 2 different. Things
So I started to look at the waste gate a little more
And it seems to be (I could be wrong ) it doesn't go the same place the bov goes so can I install both ?
Or am I completely off here ??????
Busser48
La
2015 mustang ecoboost
Yes you are completely off, give me a minute I'll explain
Busser48
La
So the wastegate is in the location close to your turbo, under your heat shield. Not sure where u bought it, but you shouldn't have to change wastegate on stock tune and no mods. Also once you do need a WG, usually the tune needs to be adjusted. The wastegate is going to control how your boost is delivered and is actually one of the best felt power bang for buck mods. A BOV is going to give you the whoosh sound and give you no performance benefites and it located close to the bottom portion of the intake tube where it starts to go into the turbo. The stock is electronically controlled and the after markets are vacuum controlled. Or you can vent to atmosphere or by a BOV adapter
chriseco
florida
I currently have a 93 tune and a cai I'm waiting on installing Adam spark plugs and his tune I recently bought the bov so I don't know if I should just. Sell it or can I install both of them if it's in to difrent location
PRG3k
Orlando
Turbo
They are two different parts not directly related to each other. A wastegate regulates your boost levels and a blow off valve relieves a pressurized intake system when the throttle plate suddenly closes. My advice, just ride around and enjoy your tune for a while.
If you're going to spend money on something, get an intercooler especially in Florida. Blow off valves will not do a thing for you.
Busser48
La
Correct, he does have the wastegate though and it is a great mod. I'll be honest with your experience level OP, I'm not sure you would be comfortable installing the WG, but that's up to you. One takes 20 min, the other takes an hour and patience
