drabon74
- Sep 19, 2014
- Conway, SC
- 2018 GT Premium 401a
What all do I need? From what I can tell it’s a bit of a process.
To his point you need to buy the automatic flange, I had to do that when I bought mine the manufacture for some reason only sends the whole differential with the manual flange.If you plan to put a lot of horsepower to it, make sure you buy one with a cast iron housing. The auto cars have an aluminum housing that the front mounts break off. You may have to swap a manual driveshaft flange with an auto flange.
Thanks. Any issues post install?To his point you need to buy the automatic flange, I had to do that when I bought mine the manufacture for some reason only sends the whole differential with the manual flange.
No problem, no issues so far. I will say you will notice a difference but imho not enough to warrant doing it. You shouldn't have any issues as long as you properly install it or have someone installs it for you. Also if you are buying the whole diff sometimes the differential fluid that comes with it will have leaked out and you will have to top it off with your own. I don't know how often this happens but just a reminder if it does.Thanks. Any issues post install?
