Borla S Type axle back / touring cat back
bobpies
N.Ireland
Mustang | V8 | Grabber Blue
Hi all
Can someone confirm for me the following
Is the borla "Touring" cat back, just the s type axle back with the borla resonator ?
If that's right then the stock resonator with the s type axle back should sound very similar / slightly quieter than the full touring cat back.
The reason I'm asking is because I've found a couple video of the full cat back touring system and compared to the s type axle back and they sound different to me - with the s type sounding a little more raspy. But surely .. if the touring system is just the s type axle back then they should sound very similar
Videos
S type axle back / stock resonator (apparently) [ame]
Full touring cat back system with borla resonator
[ame]
Hopefully someone can clear this up for me :)
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Yes. Confirmed.
beefcake
Bethel
2018 Ford Mustang
Correct
bobpies
N.Ireland
ok great thank you - i guess its just the angle of the videos / different cameras used then that's making the above shots sound different
Sasuketr
Chicago,IL
2015 Ingot Silver GTPP
I had the borla touring catback with the resonator, and I replaced the resonator with the x pipe which made the entire setup a borla stype.
TexasRebel
Gearshifter
between the mustard and the mayo
2016 YZ GTPP - PP2
I just installed the S-Type Axle-back, and love the sound. Much better than stock (there is actually sound), and no so loud that it might aggravate the neighbors when I leave for work. It's about as close to the old muffled carbuerted V8 sound you'll get with fuel injection.
After a 400 mile trip this weekend i can also confirm there is no drone under 2,500 RPM.
Myke
NSW, Australia
2017 Mustang GT
With the S-type cat-back system, will the stock resonator still fit? without doing any cutting? i.e straight swap with the x-pipe?
Would be good if it does as an option to be able to tone the volume down if required.
kingstang
New Jersey
2016 GT
You would need to cut the stock resonator to do a cut n clamp.
