Boost gauge and mounting options? ‘19 Mustang GT
Stang 19
Ca
2020 GT500 Ford Performance Blue
now that my Edelbrock stage 2 is installed, dialed in and running like a champ, i’d like to install a proper boost gauge. Other than swapping the vac guage in the dash with the ecoboost vac/boost guage, what are all of you doing for one?
Stang 19
Stang 19
Ca
Pictures and make/model of gauge and mount will be very helpful, please!
DavidHuff
Salem,OR
Go to Ebay(Vent Gauge Pod 2015 Ford Mustang Gt)
Pictures and information for 52 MM Boost Gauge
Price:$47.99
Jobodizo
Kentucky
2015 DIB GT
Stang 19
Stang 19
Ca
Curious if anyone has replaced the center console mounted oil pressure and vacuum gauge with the Ford performance oil pressure and boost vacuum gauge ...seems like a no brainer since it is a plug and play operation ...thoughts ?
CraigJ
Wakefield, UK
2016 Mustang GT, 97 Westfield SEW
You can activate the digital boost gauge using forscan but the boost is just a calculated estimate rather than actual pressure reading from a MAP sensor.
maxchaney
Colorado
I did this. I have a 2016, but it was simply plug and play. No programming or forscan updates, it just "worked." I know it probably isn't completely accurate since it is a calculated value, but it looks good and it was easy to install.
Stang 19
Stang 19
Ca
Thanks to all of your replies with your suggestions and ideas . Just ordered the auto meter cobalt unit and will install it in one of my center AC vents using an adapter . I could not figure out what order of magnitude the accuracy was to do the eco-boost swap so I will spend some time under the dash routing electrical and vacuum lines not such a bad thing !
kwikS550
Phoenix, AZ
2017 GT PP
I'm running the ecoboost gauge swap too. Super easy & clean install. It reads what I expect it to based on edelbrock's psi claims with the kit.
ahl395
Allan
Autometer A pillar gauge pod.
