BMR RH017 washer size help?
Jjmoberg
KC, MO
Jeremy
2022 Mach 1
Having my RH017 kit installed on Friday with some other projects Ive been putting off and just realized there are no washers in the box. Can anyone tell me the OD of the washers for the 35, 65, and 100 mm bolts? I think i have some that will work for the 35 and 65mm, based on some install pics online. Bit the 100mm washer looks a bit larger. I think the lock washers are easy enough but I want to make sure I have the right sizes for the stainless washers.
Thanks all!
John S
Novi, Michigan
2022 Mach 1 HP
Jjmoberg
Jjmoberg
KC, MO
Jeremy
2022 Mach 1
Can the drilling for the through bolts be done with the subframe in the car? I bought some Kelltrac studs to be able to lower the subframe a couple inches.
John S
Novi, Michigan
2022 Mach 1 HP
Good question, sorry I don't know. I'm spoiled by the luxury of owning a lift and I made a fixture to drop my cradle when I performed all of my rear suspension/chassis/roll bar mods.
