Stuntman
So we're confident the OEM 295 is the 10" tread width tire? How will the 305 rear go from a 10.7" tread width to a 10.9" tread width when mounted on R wheels?I think you guys are pulling up a regular MPSS and not the GT350 MPSS.
Actually rim width range front is 10-11.5 and rear 10-12. The tread width you stated is correct but on an R spec wheel will measure 10.2 and 10.9" accounting for the wider rim.
https://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Pilot+Super+Sport&frontTire=935YR9PSS&rearTire=035YR9PSS&vehicleSearch=true&fromCompare1=yes&autoMake=Ford&autoYear=2016&autoModel=Shelby%20GT350%20Mustang&autoModClar=
Did he really recommend OEM GT350 tires on R wheels? Have you read this? (seems outside his own stated range):
http://www.motoiq.com/MagazineArtic...LY-select-and-size-TIRES-for-PERFORMANCE.aspx
“For ideal handling: when sizing a tire for a given wheel, I usually target a tire’s TREAD width to be as wide as the WHEEL width, or 0.5” narrower than the wheel width.”
