So what xbox game...eh...errr... simulator helps you most.? LOL bwhahahahahha just picking on you.I use racing simulators regularly. They’re so accurate that they can help you improve your car control abilities dramatically..they’ve helped me improve my driving skills.
Not stock, anyway. But even if you were only at the 375-ish level in years gone by, it wasn't like you were on tires with the capabilities that the better tires today have either, or that your car back then would have had a suspension that remained as composed when pushed. So the resulting incident probably wouldn't have happened at quite the same speed or with quite as much momentum, it still would have happened. And I suspect that more of the 'almosts-but-not-quites' would have ended up really happening.Thanks Norm. Not to disagree with what you wrote, I'm just suggesting that not taking advantage of the technology or thinking that you can handle an unexpected emergency better than a computer that is standing by, un-distracted, is perhaps unwise. Of course it's best to avoid those situations. Of course you can't turn off the traction control or ABS on a 1980 Mustang. But it didn't have 465 horsepower either.
I guess it would sound nuts if you've been conditioned to believe that they are absolutely essential to safe driving. But to me that implies that I shouldn't be where I am with 55+ years of driving under my belt. I've even suddenly hit patches of spilled coolant at around 1g in the middle of a corner (on the track, not my coolant) without incident. Apparently, it really can be done without "help". I was 69 years old at the time.I read so many guys on these forums write "the first thing I do after I start the car is turn off the <stability control acronym> before I start off". That's nuts.
Would have to agree, while I dont have the years you do I am pushing past 30 plus years of driving and god knows how many cars maybe 35 or so... this is second car I have had with nannies and modern traction control. Not sure how I survive all those years with out nannies and how turning it off now doesn't just slam me into the ocean and hit a whale or something. Not sure why some think turning off the nannies is "stupid" the off button is there for a reason...I guess it would sound nuts if you've been conditioned to believe that they are absolutely essential to safe driving. But to me that implies that I shouldn't be where I am with 55+ years of driving under my belt. I've even suddenly hit patches of spilled coolant at around 1g in the middle of a corner (on the track, not my coolant) without incident. Apparently, it really can be done without "help". I was 69 years old at the time.
Norm
No, anybody who drives at 1g on the street is nuts. No matter how good the road conditions might be.Turning off the “nannies” on the street is nuts. There is a big difference between hitting some coolant on the track (remember a controlled environment) and being on the street with animals, potholes, other drivers, unfamiliar road conditions, weather, etc.
And it's still no different from when there were no electronic safety nets and it was 100% on you to drive far enough below the limits of car, road conditions, and your own skill set, with consideration for situations likely to arise, that there was still enough left to cope with the unexpected. It's not about assumed driving greatness, it's about staying within capabilities. There's a difference. Believe it or not, that approach does work. Maybe that means I wouldn't ever drive a Mustang the way all the street racers and show-offs seem to think I should (kind of back to topic), but I'm good with that.It’s not a matter of you’re survival for the last however many years, the point is flying over your head. I don’t care how great of a driver you are, there are times when you aren’t 100% (and that is assuming that you’re really even as great as you think you are). You’re tired, distracted, whatever.
Turning off the “nannies” on the street is nuts. There is a big difference between hitting some coolant on the track (remember a controlled environment) and being on the street with animals, potholes, other drivers, unfamiliar road conditions, weather, etc. It’s not a matter of you’re survival for the last however many years, the point is flying over your head. I don’t care how great of a driver you are, there are times when you aren’t 100% (and that is assuming that you’re really even as great as you think you are). You’re tired, distracted, whatever.
The world is full of people who had things happen to them they never thought would. The off button is there for times when you’re in a controlled environment, and want to explore the limit without interference. It isn’t there to turn off on your Sunday drive.
I'm with Chris on this, but also getting off of your nicely tended grass and I'll just sit over here and have some popcorn.You can think however you like, but statistically speaking, traction control, abs, and other driver aids result in far fewer accidents than if they were absent. So anecdotal stories aside, leaving them on make “people” safer. But I got it, I’ll get off your lawn.
Obviously you've never encountered a situation where stability control or traction control system intervened long before it should have. If you had, you might be taking a less arbitrary position here. Yeah I realize that wouldn't be 'politically correct' in this day and age.You can think however you like, but statistically speaking, traction control, abs, and other driver aids result in far fewer accidents than if they were absent. So anecdotal stories aside, leaving them on make “people” safer.
