Back 1/4 window weather strip
dirtwarrior
kentucky
Joe
2015 3.7 mustang
The weather strip on my back 1/4 window has torn. Tried many things to repair it which did not work. I need to replace it. Links please
Skye
≈39N
"Skye" Mach1 N2144
So, I'm going to defer on this one to @LevittownFordParts . Using your VIN, they will work with you to confirm the correct part and make it available to you.
There are "belt", "weatherstrip", "trim" items available for the rear quarters. For convertibles. See the attached links. These small strips attach to the inside of the quarter panels.
https://parts.levittownfordparts.com/oem-parts/ford-belt-weather-strip-fr3z76297b07b
https://lmr.com/item/LRS-76297B07B/mustang-quarter-window-belt-weatherstrip-lh-15-22
But I believe you're going to want a similar item for a hard top. In that case, see this link. The eBay link has photos of the assembly.
https://parts.levittownfordparts.co...s-jr3z6329711c?c=bD0xMSZuPVNlYXJjaCBSZXN1bHRz
https://www.ebay.com/itm/1666444346...PAFQEB&hash=item26ccc846d9:g:-TQAAOSwB3Vl8LrX
You might be looking at purchasing an entire window, weatherstripping attached, all as one unit. From my initial searching, it seems for hard tops, your only option is to buy a window unit. That's how they are built and sold.
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
Mine is a convertible and you may be right to get the weather strip is attached to the glass.
Skye
≈39N
"Skye" Mach1 N2144
So the vert item is what you are looking for. Good. Levittown can work with you to confirm the correct part number for each side and ship them to you.
The vert weatherstrip/belt will be cheaper and I believe easier to install than if you had a hard top. Removal of the interior plastic panel, or at least backing away of the upper part will be required. IDK how the quarter window sits. You might need to free this up as well, to access the weatherstrip, quarter panel fasteners.
Along with the strip, I'd work with Levittown on getting some interior panel fasteners. Odds are good you're going to break or lose some of those when freeing the interior panel for access to the weatherstrip.
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
It is not shown on the diagram. It is actually the rubber attached to the glass
LevittownFordParts
Worldwide
Benny & Mitch
S550's!
