Australian All In 17 build (Pic Heavy)
Matt-23
Matt-23
Brisbane, Australia
17 Mustang GT Race Red
So more news, still waiting on the head gaskets however the sump came in and fitte. Fitted the oil by pass fitting from Improved Racing to fit a remount oil filter adapter. The Improved Racing stuff is unreal very well produced and packaged with outstanding instructions. Also fitted the MMR Head cooling mod which again was easy to instsall and makes sense why its made.
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Will you please share your understanding of why this is beneficial?
Matt-23
Matt-23
Brisbane, Australia
I was reading somewhere that the rear cylinders get hot by the time the coolant reaches the rear and almost pools there (I might be wrong) I would like to modify it so it flows back into the coolant line somewhere else. So coolant is always flowing past the jackets at all times.
bnightstar
Bulgaria
Hristofor
2013 Ford Fiesta 1.25i, 2017 GB Ford Mustang GT PP Premium
Just make sure to install driver side catch can if you are doing this as now you will have much more oil flowing into the driver side head so more oil to catch. As I understand it this is needed in order to have more oil flowing to rear driver side cylinders and prevent common engine failure when the oil flow is reduced there. It's something that I plan to do to my Coyote as it will surely help. Can you link the kit ?
Matt-23
Matt-23
Brisbane, Australia
So the ups and downs of building your own motor. Fitting the harmonic balancer I snapped the installation bolt that came with the kit. bye bye crank. New crank ordered and balanced and re installed. What a head ache. Now I have a spare chank with a bolt stuck in in it. Got it all back together with the balancer installed.
Matt-23
Matt-23
Brisbane, Australia
So motor is stripped down again to start fresh. Rebuilt it up up again. taking my time with getting the timing correct and all the wires in the correct spot.
Matt-23
Matt-23
Brisbane, Australia
Decided against using the factory oil cooler so are using on from Innovate Racing moves the oil filter from the factory location to where you want it, very please with it! PS Below photo was borrowed but its in the exact same place.
GT 550
Australia
Black GT MT S550
G'day Matt thanks for the update. Well that sucks, how did it happen? No way of getting the bolt out eg spark erosion?
