ATI Super Damper install
Silver Bullet
Houston, TX
Robert
2015 Mustang GT Procharged Auto Silver
For the ones that has installed ATI Super Damper , do you line up the keyway on the hub with the dimple & the arrow also on the shell are does it not matter the orientation of the keyway on the hub ? Thanks for info.
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
Dot to dot. It will only line up one way including rotationally. It has an extremely limited tolerance of assembly.
Silver Bullet
Houston, TX
Robert
I'm talking about the hub that goes on the crack (hub keyway) , the shell assembly was already put together where the arrow & the dimple were lined up already, but does the keyway need to line up with dimple & arrow also ?
Silver Bullet
Houston, TX
Robert
type o (crack) , meant CRANK
db252
Equinsu Ocha
Bay Area, CA
That has no bearing on the install. The ati is perfectly balanced so you can install that hub with the three longer bolts however you want. I believe we are talking about the same thing now.
Silver Bullet
Houston, TX
Robert
OK , yeah the crank hub & shell came as 2 separate pieces that I bolted together, the hub part that goes on the crank has a keyway , does that keyway have to line up with other marks on shell ? I guess it odes not ?
