Are These Engine Air Filters The Same?
akoster
Atlanta, GA
Andrew
2020 Mustang GT Premium w/ Performance Pack
My car is at 65k miles, so I was going to replace the enginer air filter in it.
I have seen these two filters online as potential replacements:
Amazon K&N Air Filter
For K&N Air Filter
They seem to be same, but I wanted to make sure. I am gonig to order the one from Amazon since it will be cheaper.
warnerwh
Salem, Or.
Warner
2017 Mustang GT/CS
The Amazon filter is a K&N. You do realize that those filters don't filter as well as a paper filter. You can see right through them. However I know K&N has sold tons.
akoster
akoster
Atlanta, GA
Andrew
The Ford one is also a K&N.
Jccams
Michigan
Jeff
2019 GT Premium, PP1, Magneride, A10
That is sold by Ford Performance. The stock Ford filter is not a K&N.
Ford Mustang Engine Air Filter Motorcraft FA1918 NEW OEM FR3Z-9601-A
akoster
akoster
Atlanta, GA
Andrew
I know. But it's one that they recommend for the car. Is it worth getting over the Motorcraft one?
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
The oiled K&N will filter better than a dry aftermarket filter. The Ford paper filters are designed to filter the best, so there’s a little bit of sacrifice in air flow. The aftermarket filters will flow better but will give a little in filtering to do so. Is it a meaningful amount? I doubt it. You’re not going to get leaves and shit in your intake from an aftermarket filter.
I have a Green Filters filter in my car, works great. I’m about due to clean it, it has about 19k miles on it. That’s the nice thing about most of the aftermarket filters, you can wash and reuse them. I have a Ford paper filter and a Ford Performance K&N filter as backups.
Paddles
TX
Richie
2023 Mustang GT
Yes, they appear to be the same.
MSheets
Lenoir,NC
Michael
2022 Mustang GT Premium, 2016 F150 XLT Sport, 2022 Edge SEL
Project Farm has a very good youtube video on this topic. The K&N was best at air flow and also worst at filtering. I personally will not use K&N on a passenger car. Ten thies the price of the filter and the oil when you wash it isn't cost effective. $16 for the wix that filters the best.
For racing engine that gets refreshed they are great.
melwff
Danbury,CT
2021 Mach 1 M2486
For K&N Air Filter
Did you notice the Ford filter says Out of Stock?
CrazyHippie
Michigan
Craig
2023 Mustang GT/CS
Nonsense. They filter better than stock, with better air flow. They are designed with an oiled element, so that particles stick, and a circuitous path to ensure that a particle hits the medium. Geez!
warnerwh
Salem, Or.
Warner
2017 Mustang GT/CS
You may want to get on Youtube and search air filter tests. There are many air filter tests that are well thought out. You will find that consistently the K&N does not filter as well as paper with proof. You can see the holes in the gauze material if you hold them up to the light.
Also if you get on "Bob is the Oil Guy" there's tons of more info on air filters. You can get a good education there.
CrazyHippie
Michigan
Craig
2023 Mustang GT/CS
SIr, I attained my deep knowledge of filtration technology through a long engineering career of filtering liquids and gases and air for sterile pharmaceutical manufacturing. If you've ever recieved a steroid shot or the COVID vaccine then you probably recieved water that was purified by filtration equipment that I helped to design and install. I don't need You-Tube.
warnerwh
Salem, Or.
Warner
2017 Mustang GT/CS
You might find it interesting that the testing shows K&N filters allowing far more dirt to pass through than a decent paper filter. You obviously haven't read or watched any of the numerous testing of air filters that have gone on for years. You contradict everybody else's findings without proof. While numerous other people testing air filters including engineers have proof that you can see with your own eyes.
Hold a K&N air filter up to the light then hold a paper filter up to the light. See those big holes in the K&N that are far larger than anything in the paper filter?
