Dark Pony
I have been fighting gremlins with my trans/shifting for a while now. So far, I've had my trans rebuilt by Ben calimer with a stage 2, installed 2 different twin disk clutches (spec and lpxhd), new TOB that was bench bled, MGW shifter (x-spec, iirc) braided ss clutch line and swapped out the Reservoir to MC feed line to a better more secure line. Most of the time my car shifts good, like a well oiled rifle bolt, but every now and then sometimes I have trouble getting into reverse or 1st, or sometimes when I'm driving I need to use a bit more effort to get the car out of gear (and sometimes although less frequently into gear). It almost feels like the clutch isn't released all the way, but idk. Another thing is sometimes I feel like a "hitch" in the clutch pedal when it's coming back up, like it got stuck for a split second. I have bled the clutch every way that I can thing of, pumped the pedal, had bench bled the TOB, put vaccum on the reservoir and pumped the pedal, etc. People seem to say that if you do the MGW then you don't need the trans bushing insert, but does anyone run both? Any benefit? I'm thinking maybe the trans is moving ever so slightly and causing issues? The only other thing I haven't swapped out is the MC. Idk. Any input is welcome.
