Anyone upgraded front pillar tweeters?
torque124
Torque
MA
Shelby GT350R
If so, can you please post what the impedance of the stock tweeter is ?
I see most of them for sale are 6ohm or less, which means it will sound much louder than the stock, assuming the stock is 8 ohm... which I read about in other forums.... I am thinking of upgrading but don't want to overdo it and scratch my years :)
Thanks a lot
Jetnoise
Raleigh NC
2018 GT Premium PP1, 70 Shaker Mach 1 stroker, 1967 F/B 357W, 1968 302 Vert, 4I 85 5.0 B&M Blower
The ohm on mine are 8.
I installed some infinity’s
Use the capacitors that come with what ever you choose to buy and or the crossover set up up your system chosen includes.
Rash
Cary, NC
2018 Mustang GT Magnetic/Showstopper Red, 401A, Active Exhaust
Tweeters are 8 ohm on the Shaker 12 speaker system. I installed some 4 ohm, and it was way to harsh, even with the provided capacitor. I plan to try some 6 ohm tweeters soon. When I finally get around to it, I'll let you know if it's any better.
ETA - sorry, didn't realize this was the Shelby forum. I don't know what the impedance is for the Shelby tweeter.
Jetnoise
Raleigh NC
Sound is a personal preference thing. What one might call harsh might sound bright and detailed to someone else. The rest of system plays a role in it as does what you listen to.
If OP is looking to just replace tweeters....save the coin for something else
Cpove
Alberta Canada
Corey
2016 GT350 2017 F150
I have the Kenwood Excelon XR-1603HR installed all around in my car with XR600-6DSP. Was kinda underwhelming to be honest....
Jetnoise
Raleigh NC
Make factory system sound not so bad?
I starting to think it’s all about the budget. Go big or don’t bother
torque124
torque124
Torque
MA
Shelby GT350R
What was the impedance of your removed, original tweeters? Was it 8 Ohm like the regular mustang ... I don't want to remove my plastics twice, would like to buy and just install, for obvious reasons... they are easy to crack and break the fixing tabs.
Thanks
Jetnoise
Raleigh NC
Thanks
I believe all the tweets are 8
Removal isn’t that tough
torque124
torque124
Torque
MA
Shelby GT350R
Thanks, I already have all 4 speakers replaced, and it sounds pretty good for 100 bucks and change... I have 2 way speakers in the doors, and they do have tweeters which I angled up, but when you close the doors there's much less treble due to position of the tweeter (low and behind the seat).
So I decided to just swap the pillar tweeters, they are hardly audible right now anyway.
I bought these 6 ohm (could not find any 8 ohm, should not be a huge difference anyway ) :
https://www.amazon.com/JL-Audio-C1-...077Q5JPTB/ref=cm_cr_arp_d_product_top?ie=UTF8
Jetnoise
Raleigh NC
Aluminum tweets have a reputation for being .....
Rash
Cary, NC
I bought the same ones and hopefully will install them soon. The description says they have silk suspensions, so I’m hoping that makes them less harsh than regular metal downs.
Ninjak
Posting from the Shadows
The Shadows
David
2024 Dark Horse Supercharged 2024 Bronco Raptor 1968 GTA Mustang
Running infinity tweaters, use the system cross over. Actually all of my speakers are the infinity system, except the center speaker.
Rash
Cary, NC
Finally got around to insalling the JL tweeters. First impression - too harsh. Even at lowest treble setting, some songs have too much treble. Probably go back to stock and keep searching. Lucking I made speakers harnesses that connect to the factory harness so easy to swap out. I can actually do it now whitout completely removing the a-pillar trim.
datadatum
JAX
'18 GT350
I installed the tweeters that came with my door speaker upgrade (Focal ISS 165). The downside is that I had to dremel the housing for them to fit (about 5 minutes per side). The upside is that they look awesome (slide right into to the modified housing on the stock A-pillar), and you can hear claps, snaps, and cymbals like never before.
