Anyone Dyno'd post tune
2015-MUSTANG
Al
2015 Turbo Mustang
Has anyone Dyno'd their ecoboost after tuning. I m curious how close the numbers are to the advertised numbers
greg hazlett
Chesapeake, VA
2017 Fusion Sport
You would have to do a before tune dyno pull as well to have baseline to compare it to...plus make sure the car was in the same gear, same transmission, sake fuel, etc..I understand why you are asking the question!:cheers:
Renner
Huntley, IL
2016 GT SOLD-2015 Ecoboost SOLD
Remember when reading results it is important to know if the dyno was a "dynojet" or "mustang dyno"
Mustang dyno has nothing to do with mustang cars btw. They usually report lower numbers as they are measuring TRUE power to the ground.
I just did my mustang dyno on the EB today and came out with 296whp/345wtq. Multiply any mustang dyno results by 1.10 and that is roughly what the dynojet will be. See my build thread for my dyno results, video and mods.
Fast64ranchero
Meridian, Idaho
Walt
63 Ranchero, 1972 Pinto, 2015 Mustang
Not always true, we have a local Mustang dyno that reads close on HP but way hi on torque. Use the numbers as a tool. I have been on many chassis dynos and a Dyno Dynamics Dyno does in fact read lower then others, but that does not indicate it is wrong... just a different reading.
OP I dyno'd my car with stock tune and MAP tune look here post 11
http://www.mustang6g.com/forums/showthread.php?t=24127
Renner
Huntley, IL
Yah guess i am using our local mustang dyno as a reference. This dyno will almost always be spot on with a 1.10 factor to what a dynojet shows...at least from my experiences with this shop over the past 2 years
dragonacc
TN
2015 Ecoboost PP
Most mustang dynos read low. If a shop calibrates theirs to read like a dynojet customers aren't getting correct numbers.
Renner
Huntley, IL
Most people don't understand the difference between inertia dynos and those with eddy current brake load.
I know I am using mine for a baseline of improvements with mods...not bragging rights like a lot of people use them for. Numbers are useless if you don't have the driver mod to use them :)
Billy G
Western Suburbs of Chicago
Bill
2015 Ecoboost Guard Metallic PP Ordered: 1/23/15
I agree with Renner. I pulled today, too. My results were 285whp/314wtq. My mods are JLT intake and MAP custom tune. That's it. No DP, intercooler or plug change. I am pleased with those numbers. I know torque should be higher but it is what it is. They are only numbers. I expect to see a substantial increase when a DP is added. The car is a brute out of the hole. Much more torque than dyno showed (IMO). But as I said, I'm very satisfied.....;)
Fast64ranchero
Meridian, Idaho
Walt
Did you pull the fuse in the engine bay that MAP listed? if not your torque will be way down.
Fast64ranchero
Meridian, Idaho
Walt
Why is that? Just curious.....
I'm not sure why, I can tell you my car was way down on Torque until I pulled the fuse.
Fuse in = 360ish ft lbs I don't remember the exact #'s but way down from what I thought it should have. Adam told me to pull the fuse and the torque jumped, interesting thing is the HP number was not down
Fuse out= 392 ft lbs
We have several chassis Dyno's here local, I'll do a couple runs on a AWD Mustang dyno and see how the numbers compare. The Dyno I'd like to put it on, is the loaded dyno I put my 2010 GT on once, I think they read a turbo car better because they can load up the turbo and hold and step RPM's
Jap Tuning
Tampa , Fl
2015 MT82 PP EcoBoost Mustang
Here is 1 of my graphs Bone stock vs Cobb @ factory 18-19psi and also a bit of tuning . The car has since made 310/395 with a bit of E30 , only mods are UPR Catless downpipe Cobb and Tune
