Anyone buying bulk E85?
Jbud
Jason
2015 gr
By the drum or anything?
Jay-rod427
Kansas
2016 GT C/S
I take an empty drum to the station and fill it while the E content is good.
Jbud
Jason
2015 gr
So far I've found 70% near me. So looking for options to get better stuff close.
Jbud
Jason
2015 gr
Found it locally and snagged one.
Tommy V
Brookly park Md
Tommy
Damm how much is a drum of that?
Jbud
Jason
2015 gr
I'd have to double check but around 300 for the drum, fuel and delivery to my garage.
kcc0521
Falls Church VA
Bo
2015 Black GT PP
I would not store it in the drum with that pump installed because it will not be sealed. I have the same pump and it does not seal.
jhatley7
2016 White GT PP, 2022 F350
Is that c85? If so that's a great price.
Jbud
Jason
2015 gr
What do you mean by not seal? They said as long as the vent is open on the pump and the spout is up I'd be fine. My garage has it's own HVAC and stays about 70 year round.
Jbud
Jason
2015 gr
I dont think its C85 exactly, they have tons of 500 gallon tanks full that they fill the barrels from he said he could mix it at any strength I wanted. It tests at 85 on the nose. It almost sounded like he makes it on site to what you want but I didn't watch.
jhatley7
I have the same. Pumping in HVAC is actually worse than letting it heat up if you keep the pump in. Moisture it the biggest concern.
I keep mine sealed in my race trailer. Only use the pump when filling jugs. No issues so far.
First barrel I left it the pump in for two weeks and it went bad. But I use VP C85
So it not actually VP fuel. I would be sure to test it each time they deliver.
Jbud
Jason
2015 gr
I will ask, it is a speed shop and they said it would be fine in the barrel, I'll test it each time I pull from the barrel since this is my first run of doing this. The shop is called Oil and Octane, they have a web site and carry both VP and Sunco full lines of fuel. Been around apparently a long time I just never knew. But thanks for the heads up. I just didnt want to risk the 70% at the local E85 stations.
