Any Tire Wizards out their??
Captian_Eddie
Spring TX
Ed
2020 GT500 DELIVERED, 2020 GT350, 2005 GT Premium, 2012 Fiesta, 2015 GT Premium, 2017 F150 Lariat,
We all know that the 2020 GT350 comes with hard to find tire sizes unless you want to run Cup2s or Pirellis I want to get some Toyo R888Rs but they do not come in a 35 bias. only 30s My question is has anyone got 295/30/10 on the fronts and 305/30/19 on the back. Any problem with running the smaller Bias tires?
TIA Ed
THX 138
Brownsburg, IN
2016 GT350 Track Pack, 2002 Porsche Boxster S 3.8L
I run 30-series Michelin Pilot Sport 4S tires in stock widths, 295/30R19 front and 305/30R19 rear, and love them. The speedometer and odometer will be off, but that is easily corrected with ForScan (GPS verified to be accurate now on my car). The shorter tires effectively reduce the rear end gear ratio from 3.73 to 3.90. Quicker acceleration, just reduced top speed in each gear. FWIW, the R models come with 30-series tires from the factory.
TopJimmyCooks
Raleigh, NC
James
2017 GT Prem PP; 2019 EcoBoost Prem
You should be able to calibrate the speedo for the new tire diameter with a cal tool like ProCal or (I think) Forscan. I don’t have Forscan, others will certainly chime in.
lunatect
Prescott, AZ
Dennis
2016 Shelby GT350
Or you can order the OEM Michelins from Discount Tire like I did. it just takes a couple months to get them. lol
guzie
Grand Rapids MI
2018 Mustang GT350, 2019 Mustang GT
Only forscan as you have to modify the as built table value for it in the body control module. I found it impossible to change through my tuner.
guzie
Grand Rapids MI
TIA Ed
Toyo R888R are a great tire by the way. I ran 305/30R19 square setup on my track wheels.
Hawkeye1
Arkansas
2020 GT350, Macan GTS, Tesla Mdl X, 911 GT3, 911S, Z4
I just did it yesterday with Forscan. It was relatively easy. The setting is in the Body Control Module, and is based on the tire circumference in mm.
Kramerica
2017 GT350
I'm running these as well and they are a great track tire. If you plan to run them on the street just be prepared because they are LOUD. Much more noise from these in comparison to Michelin SC2 or SS.
P85596
California
Robert
2018 GT350
I'm running Michelin Pilot 4S 305/30r/20 on all four corners and I can't tell any difference in ride other than the tramlining has all but disappeared. Before I mounted them I did an eyeball comparison with the 19's while they were on the car and the size was almost identical so I'm guessing speedo error is at a minimum.
guzie
Grand Rapids MI
Yep. There is a good thread on it. It’s not as daunting and scary as it sounds
guzie
Grand Rapids MI
Agreed. I ran them first as a street/track tire for a few months until I got a second set of wheels for just track use.
dboz1983
Indiana
NA
'16 F150, ‘20 GT350
FWIW, I just got Pilot Super Sports in OE GT350 sizes, front and back, from Tire Rack. Ordered a week ago, they delivered to my door yesterday.
guzie
Grand Rapids MI
Those are ok but not as sticky
