Any Problems with Aftermarket Grilles
SamR
Plano Tx
Sam
2020 Ford Mustang GT
Hey, I currently have an MP concepts grille with both sides open, I wanted to hear from yall if all the extra air going into the intake has caused any codes or problems for you. I'm currently having trouble with P061A and P061B codes. Thanks!
Justgonna send it
NC
Ty
2019 GT 6spd ess G3 kit 120mm pulley , wendgerd tune & 2020 hpp eco
Did u find a cure. I had the exact same thing with this exact same grille
stannypack
NOVA
2022 Mustang GT
Well shit I bought this same grille and plan to install it soon, that's not good to hear. I'm assuming you're not tuned?
MCS
SW Ontario
Michael
'24 DH Premium
Odd that this would be throwing a code as there are many people out there that are running after-market grilles/inserts on their cars without this issue.
Are you tuned?
Did you follow the instructions for checking the root cause of both codes?
I just did a quick lookup on the one and it recommends pulling your air filters and ensuring you aren't running around with clogged stuff.
When they installed my supercharger they removed the front flappy flaps so I know there is a TON more air being sucked into the engine and it doesn't throw any codes whoever that's because it was tuned for that level of air intake.
Justgonna send it
NC
Ty
I’m tuned. (PBD). I’m going to get a new filter and AquaShield from injen and see if that helps. When I pulled the filter it was dirty. It doesn’t throw the code until I pull my codes with nguage.
