MikeHTally
- Apr 22, 2019
- North Florida
- Mike
- 2015 EcoBoost Mustang, 2020 Explorer Limited
- Vehicle Showcase
- 1
Wow! A 3.31 ratio will turn the driveshaft 3.31 times for every turn of the rear wheels. Or, one turn of the wheels will spin the shaft 3.31 times. That applies to all ratios. A 4.56 will spin the driveshaft more times in a tire rotation than a 3.31. Motor speed will be a factor of the gear ratios in the transmission. Driveshaft RPM is totally dependent on the final differential ratio.Your two posts make absolutely no sense and are contradictory. First you are talking about running the engine to redline then immediately follow up with a warning about the driveshaft spinning too fast. The rear differential ratio has nothing to do with the driveshaft RPM. Changing the differential ratio affects the half shaft and tire RPM. The driveshaft RPM is determined by engine RPM and transmission ratios. If you're worried about driveshaft RPM you must never go above 50MPH because that would make the driveshaft spin too fast, right, or do you just shift into sixth gear at 20MPH to play it safe with driveshaft imbalance?
