boB
If the driveshaft is spinning at 4000 rpm in 4th and we downshift to 3rd the engine will rev to 5680 but the driveshaft will still be at 4000.The speed of the drive shaft is dictated by the internal gearing of the transmission. So if the engine is running at 4,000 rpm, in a gear that is 1:1, the driveshaft is spinning at that 4,000 rpm. The rear wheels are spinning at 877rpm. If you down shift to 3rd, and that ratio is 1.42:1 as it is on the MT82D4, that will bring your engine RPM up to 5680, causing the driveshaft to spin at that speed, but the car will be going the same speed, because the rear wheels will still be spinning at 877rpm. (5680Ă·(4.56Ă—1.42)).
