drewzh
- Jan 21, 2018
- Manchester, UK
- Drew
- 2018 Mustang GT, Magnetic Grey, Magneride
- Vehicle Showcase
- 1
So many of you have probably heard about the CAN bus immobiliser you can have installed in the UK - the Auto Watch Ghost. This is a pro-install only product that costs £400 to have installed.
However, what most of you probably don't know is that this product is actually a re-branded product sold overseas under a few different brand names, one of which being the Ampire WFS300-BT. This is the exact same product, minus the pro install - even the Android and iOS app is the same but with a different logo and colour scheme.
The Ampire WFS300-BT can be purchased online for as little as £179 and installed with some reasonable electrical skills and a few hours to kill.
I personally like to do everything on my car myself (minus a few things like tyres and alignment etc), so paying someone else to splice into 4 wires just seemed a little steep.
The recommended approach for installing these is to wire them directly to the OBD port wiring (and I imagine this is how the 'pro' installers are doing it)... Considering the wiring is so easily accessed - All that's required to disarm the immobiliser would be cut any of the 4 wires, so having it in such a vulnerable spot seems a bit insecure - even with the possibility of anyone knowing you have an immobiliser installed being quite slim, I didn't like the idea of this at all so I decided to install mine in a hard to reach spot...
I wanted to install it somewhere fairly deep into the dashboard so that even if the thief knew I had an immobiliser installed and even knew *where* it was installed, it wouldn't be feasible to try and removed the module as it would be too time-consuming/risky.
After doing some research, I found that the HS1-CAN wiring can be spliced into from behind the sync 3 module on the APIM connector. This is quite a difficult part to reach so it's extremely unlikely that anyone would go to the trouble of trying to remove it, even if they knew where to look.
So I removed the various dash pieces, removed the 4 bolts holding the fascia in place, removed and unplugged the various cables from the facia, removed the 4 bolts from the touchscreen, then removed the touchscreen/sync module and installed the Ampire into the APIM connector that goes into the back of the sync module.
I used self-soldering, self-sealing heat-shrink tubes - I'd never used them before and I'd say they do a reasonable job. I then wrapped everything back up with Tesa tape (much like the OEM fabric tape Ford use) to make everything is stealth as possible. My only worry at this point is that if I die, nobody will ever know the immobiliser is installed and the car will have to be scrapped
Pins used on the APIM cable are:
Pin 1 = 12v
Pin 37 = Ground
Pin 53 = HS1-CAN High+
Pin 54 = HS1-CAN Low-
Anyway, I hope this helps someone. Please let me know if you have any questions.
Test install of the Ampire WFS300-BT - PIN now setup and working as expected:
Ampire WFS300-BT Wired up:
Self soldering, self sealing, heat-shrink tubing:
First length of Tesa tape wrapped:
Final wrap of Tesa tape added:
At this point it's quite impossible to tell the immobiliser is installed:
Touchscreen bolted back into place:
Pin 1 = 12v
Pin 37 = Ground
