nikolai
So I live around Denver (~5280ft). I checked an online calculator and it says my atmospheric pressure is 12.14psi at 75F. That's roughly 2.5psi below atmosphere at sea level. So if I were considering something like Procharger kit (I am) which I think comes with a 9psi pulley, I'd have to pulley up to 11.5psi to get the same power. How do I calculate the expected pressure that a pulley can produce? I see lots of online calculators for that, but they all ask for various parameters about the car, that I don't know how to answer.
My second question is about head unit sizing. Let's assume I'm going to focus on offerings from Procharger. Initially, I'd want to run lower power to give myself time to sort gremlins, but I'd want to size the head unit to max out on E85 up to 800-900hp (I doubt I'd actually push it that far). A P1SC is rated at 825, but that's likely only on race fuel and at sea level. Should I just start with something like a D1X knowing I will need to run more boost from the get-go? Is there a limit to how much power I can get on E85 (timing limited I suppose)?
