Alarm going off when disconnecting battery
Stangfan333
Hobart,Tasmania
peter
2020 GT manual
Hi,when I go away for a few months I disconnect the battery negative lead,but then the alarm goes off for about 5 minutes then stops.Any tips to avoid this please? I can't use a trickle charger as carport is too far away.Thank you.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
This happened to me with an older KIA SUV. The car does this in case it is being stolen.
I suppose you could locate the fuse for the horn and pull that. Then replace the fuse and cable when you are ready to go again.
howlins550
Cincinnati
2019 mustang GT PP1, 401A, 10R80, Magneride, Active exhaust, Oxford White
I feel you! That alarm going off for 5 minutes can be super annoying! One tip that might help is to use a battery saver or a memory saver device. These devices connect to your car's OBD-II port and keep the alarm system powered, so it doesn't think the battery is dead.
Another option could be to use a solar-powered battery maintainer, which can be placed near your carport. These devices are designed to keep your battery topped up, even when you're not using the car.
FMGTV8
AUSTRALIA - South West Victoria
use to own - "2017 Mustang GT V8 Ruby Red Manual"
This happens if you disconnect the battery when the car is locked.
Just unlock the car then open the driver's door - this de-activates alarm.
Then shut the door, make sure everthing is turned off and don't lock the car then disconnect the battery. ..... easy fixed !!!
Stangfan333
Hobart,Tasmania
peter
2020 GT manual
Stangfan333
Hobart,Tasmania
peter
2020 GT manual
