Air to Air IATs
BARNESGN
High Point NC
Sam
G8 GT 15 Q50 S 15 GT Premium PP
What kind of IATs do the Centrifugal supercharged cars see on 75 degree days. I’m trying nail down the benefits of going to a Vortech setup. Anybody have some good data logging on intake temps?
Bmaughan
Az
Ben
2015 procharged mustang gt
What kind of info are you looking for? Idle temp? Boost level ? Length of pull? All those things really affect iat...
Bmaughan
Az
Ben
When cruising most see only a couple degrees above ambient.
Bmaughan
Az
Ben
His profile shows that he owns a 15’. It doesn’t have a iat2.
BARNESGN
High Point NC
Sam
BMAUGHAN that’s perfect. Thank you.
Jackson1320
California
Jaxson
2015 mustang gt
He needs a dedicated ZT-2 unit to read IAT2 close to the TB, and use that for a reference for his tuner
I would just use a break out harness and a iat sensor by itself separate from the maf. That’s how I run mine for my water/meth
Stymee
Delray Beach, Fl.
Joel
2019 Mustang GT
That’s cheaper for sure if the IAT2 pid is in his 15 Ngauge or SCT device?
Jackson1320
California
Jaxson
2015 mustang gt
The zt-2 is good but if you just want I.A.T at the throttle body. I did it for about $50
it will show as your iat1 just let the tuner know that you moved the iat sensor. Use the ambient air sensor as you iat1 data and the iat sensor as iat2 data
Stymee
Delray Beach, Fl.
Joel
2019 Mustang GT
Ahhh, ok that’s smart :thumbsup:
ahl395
Allan
Cruising:
4.75" pulley +3F over ambient
3.85" pulley +4F over ambient
WOT:
4.75" pulley +20F over ambient
3.85" pulley +40F over ambient (3.85" pulley w/meth injection +25F)
SolarFlare
S. Fla
2015 CO GT
I used to see a couple degrees above ambient before. Now with IAT sensor in the manifold it’s usually 15* or so above ambient. When I go wot it will drop momentarily
watisthis
Odenton, MD
Justin
2015 GT Pro-charged
Cruising:
WOT:
This is so weird to me. 3.85, and wastegate too and I'm sitting at like 15-20 above ambient cruising in 5th like 2600-3k rpm.
