Air fuel ratio really rich (2018 Mustang gt)
maxcraig00
Max
2018 Mustang GT Automatic
Hey guys quick question.(2018 mustang Gt JLT CAI, E85 tune). I have been getting code p0003 on my lund tuner. It says heater control circuit. My air fuel ratio is super rich. 8.5-9.8 on idle and doesnt change on WOT. Sometimes it jumps to 10.5. I am currently on E85 and it been on E85 for the past 6 months. I tried cleaning my MAF sensor. I dont know what the problem is. But it seems I am running to rich.
blackyote_317
IN
Adam
2017 GT
I'm not on e85 but I'm pretty sure that's exactly where your AFR should be...I don't think that has anything to do with your code.
SheepDog
Colorado
Dax
Iconic Silver 2022 MACH 1 HP
Your AFR is about right for E85. Just depends on the actual alcohol content. Perfect Stoichiometric ratio for E85 is 9.8:1
SheepDog
Colorado
Dax
Also, code P0003 is a generic OBD2 code for Fuel Volume Regulator Control Circuit Low. It has to to with your high pressure direct injection system. Check the fuel rail pressure sensor, connector and wiring
3star2nr
Ray
2016 Ford Mustang GT PP
Check for vacuum leaks down stream of the mass sensor.
Check for bad o2 sensor.
Contact lund, send data log
SheepDog
Colorado
Dax
Vacuum leaks cause a lean condition, not a rich condition.
SheepDog
Colorado
Dax
Which none of those are present in the OP's post, so not sure why he's having him go on a wild goose chase for a phantom problem.
Truth. The moral of this story is that there is no problem. OP's AFR is correct for E85.
