ABS speed sensor replacement
FUN2RIDEFAST
Ofallon, Missouri
2017 Mustang GT Premium/PP
Just replaced left rear wheel speed sensor and still have abs, traction control, power steering and advance track lights on the dash. I just disconnected the battery which should reset abs and traction control. Does the car need to be driven to get the advance track and power steering lights off?
BoostedYote
Nebraska
Brice
2015 Mustang GT
Did you ever figure this out. Im experiencing the same
FUN2RIDEFAST
FUN2RIDEFAST
Ofallon, Missouri
Did you pull the codes?
Codes came out speed sensor and ring. Sensor was changed three months ago but I'm putting a new one in because a bad sensor will also throw a ring code. There's no slop in the hub whatever so I'm going path of least resistance for starters. The ring is part of the hub assembly that the sensor takes its readings from.
Zrussian13
Phoenix
My wheel had no play either and it was still the hub. This issue comes up often and the majority of the time a new hub solves it.
I did have to drive mine for almost a week before the codes cleared. I could clear most of them but not the abs.
FUN2RIDEFAST
FUN2RIDEFAST
Ofallon, Missouri
I have two new hubs and if the sensor isn't the problem I'll change both.
Grady_
Ohio
2018 Ford Mustang GT Premium 401a
Was new hubs the fix? Dealing with the same thing right now, caused by an automatic touchless carwash shooting water at my wheels. Not sure if its the sensors or the wheel hubs
FUN2RIDEFAST
FUN2RIDEFAST
Ofallon, Missouri
Car wash has nothing to do with it. I've been through it and ended up doing hubs after changing speed sensors. However, everything worked for a short time after changing speed sensors (two weeks) before everything shot craps again. Then changed hubs.
Grady_
Ohio
I will start with the sensors then check the hubs then. Thanks.
