A/C problem
slowhand99
Surrey, England
Ben
Mustang GT Vert Race Red ord 26/03/15 del 24/03/16
well out of the front 5 vents (Two to the side, 3 in the middle), the drivers right side and left side, ar eblowing hot, the other 3 blowing ice cold.
RIP Manders Evap core.
Booked in Tuesday to be looked at. Can't wait to have my dash ripped apart. :@
Surely if your evap core has gone, they'd all blow hot?
Manders Mustang
The Boss
Birmingham - United Kingdom
2016 Race Red Ecoboost
Not from what I was reading on the other threads. :shrug:.
By equal discretion, if the gas/refrigeration had gone would they all not blow one temp?
avocet
Kent, England
Ted
Mustang GT
I would guess its not your evap core.....yet
you are still getting cold in the middle 3 it could be a blend door or temp valve.My one did some strange things before it was the faulty wiring loom diagnosed.Someone else on here had similar to me and it was some control valve.
Manders Mustang
The Boss
I actually whacked the A/C on today, it was fine, Someone else had mentioned the blend door, no idea what this is, but it seems to be "ok" for now - I've rang ford and told them but it needs to go in for a leaky timing cover anyway (common issue with the EBMs) just needs resealing this time. :lol:
blueboy
london
Barrie
Dib GT and vw transporter
Well not quite a month since being told all it needed was a regas and it's blowing warm air again.
You couldn't make it up!!
Eclipsar
UK
NFG Mustang GT
That’s because it has a leak and they wanted to just charge you to re-gas it
blueboy
london
Barrie
That's what I said at the time, I also said that when it happens again I would be bringing it back to them and will be demanding a refund.
Eclipsar
UK
NFG Mustang GT
:thumbsup: I think Ford Services is used to dealing with idiots or they just can’t be assed to fix something :shrug:
blueboy
london
Barrie
I think that just about sums it up.
slowhand99
Surrey, England
Ben
You don’t have to make it up, Ford do it for you.
Regas = leak.
There’s some good mobile air con guys about. I’d use one of them, then enjoy the air con and the punch up with Ford through the claims process.
avocet
Kent, England
Ted
Mustang GT
Sorry to hear this
These units do not come from the factory half filled,this is bull.If your blowing hot air on AC you have a major component failure or a evap core leak.Ford know this, it is well documented but some dealorships cant be bothered to pull your dash.Re gasing is just the easy option.
When my heater failed drivers side it took me a few visits to prove that i had a continuing problem.They diagnosed the faulty wiring and pulled my dash out and renewed the loom and connectors.
Entai
Bedfordshire
2019 GT kona Blue, A10, Magneride, CP 2. Daily Driver
Sorry to hear this
You do know that by official regulations on vehicle based AC it is ok to loose 20% of your gas in a 12 month period, that is not classed as a leak, that is allowable loss.
If any dealer or company be it mobile or fixed do a re gas the correct procedure is to do a leak test first.
Drain all existing gas and liquid, fill with nitrogen and leave for at least 2-4 hours preferably overnight.
That way you will determine if there is in fact a leak (if anything) and where it is, could be any number of places.
Then fix or replace and re fill.
Silver Surfer
Sheffield
EcoBoost Convertible Auto Custom
My wife's Nissan Micra A/C has gone 13 years without a re-gas or service and still works fine.
America is the home of A/C systems, - why can't they make them like this today?
avocet
Kent, England
Ted
Mustang GT
My 8 yr old fiesta van is still blowing out ice cold air
Never been touched
Some of the mustang parts just keep on failing,and they continue to fit them.
Eclipsar
UK
NFG Mustang GT
The trouble with Ford service is, because Ford recommend aircon on a Mustang to be regased every 3 years, they then decide a car that is close 2 year old needs regassing as it’s close to 3 years old :shrug:
