6R80 Transmission Mount
Blown15S550
Kentucky
Lance
15 Mustang GT / 89 LX Coupe
Hello, i cannot find the 4 mounting bolt to the chassis torque specs. What is recommended?
Transmission Cross Member (18mm): 85 ft/lbs.
That info comes from this below thread.
https://www.mustang6g.com/forums/threads/torque-spec-of.89767/#post-1989481
There isn't any additional info as to if those specs are the same between a 6R80 or MT82 trans mount. Accuracy has not been verified, so if there are additional questions you can try reaching out to the OP or a local Ford Dealership...
Blown15S550
Kentucky
Lance
thanks, they shall be the same as same size bolt just different designed crossmember.
