3.7L belt squeal....
RemoteSenses
Michigan
2015 Mustang V6 RR
Got the car back from service today. They replaced the main accessory drive belt and it seems to have fixed the squeak. We shall see as time goes on if it returns. So far though it seems like an easy enough fix!
Thanks for the update!
I originally replied to you when you posted this thread a while back; had the same issue.
But, it actually seems to have gone away. I used to hear it almost every time I started the car, but now I haven't heard it in a few weeks. Guess I'm going to leave it alone for now.
Glad to hear they serviced it for you! Hopefully they fixed it!
zackmd1
zackmd1
Zack
It is back.... :mad::tsk:
The tensioner has got to be the issue. Once a new belt wears in the tensioner is not putting enough pressure on the belt to keep it tight.
Maddog1337
Chicago
2017 Mustang V6
Did you ever figure this out? I have the same squeal on my '17 and it's getting quite annoying.
zackmd1
zackmd1
Zack
A new tensioner and the lightweight water pump pulley from MMR solved the issue for me.
Maddog1337
Chicago
2017 Mustang V6
Thanks for the update on an older thread. Sucks to see it took such an undertaking to remedy. I suppose if it's not harming anything I can live with the defect. However, while I'm still under warranty I might try to reference the TSB you posted, so thank you for that.
