275/40/17 MT drag radials ss
Viperbluecobra
Houston
2015 Mustang GT Base PP Recaros
Figured that 275 wide is still enough for a n/a application. Ordered them should have them friday.
anyone else running 275 wide drag radials?
I had 305 nitto nto5r's and they rubbed the fenders a little bit on hard launches.
Viperbluecobra
Houston
additionally, is that too short of a tire?
Hyland33
Leicester MA
2016 GT/CS
They will be shorter than the factory setup, and they look kind of funny. I'll be ordering some M&H racemasters soon. They're the only company that makes a 275/50/17 which is the right height. I don't want to run a wide tire so the Mickey Thompsons are all out.
poncho@home
GettingOld
Laval, QC
2017 Mustang GT Premium
Actually, depending on transmission and rear end gearing, the 275/40/17 might be beneficial.
A 275/50/17 is taller than all the OEM tire sizes on the GT.
Ex. a 255/40/19 is 27", 275/50/17 is 27.9"
When I did the math for RPM through the traps, a manual car with a 3.31 rear will likely benefit from a 275/40/17 vs a 275/50/17 at "stockish" power levels.
All this is only for drag racing consideration, not everyday street use...then my points are no longer valid
That's likely the size I will be getting next spring for my dedicated drag setup.
