26 or 28 inch tires???
Crusch84
Pittsburgh
I have a 2018 Mustang GT performance pack mt82 car with 373's. Tuned on E85 with long tube headers so nothing to crazy power wise. I'm leaning towards 28 inch tall drag tires or should I go with 26 inch tall tires? Thank you in advance!
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
28 as long you're not lowered too much.
BmacIL
Enginerd
Naperville, IL
Crusch84
Crusch84
Pittsburgh
Does anyone have trouble with the 28 inch tall tires bogging on a manual car?
Chummel
Tulsa, Ok
2015 Mustang GT PP
I’m lowered an inch and run the nt555r in a 305. It is a 28.5 inch tire and I have zero rubbing, even have a little room to spare. I don’t bog down with my manual but then again I have bit more power than stock.
Crusch84
Crusch84
Pittsburgh
Thank you! What's your power level? How are you launching? Traction control & advanced trac off and slipping the clutch. Or are you using the launch control
thelostotter
AZ
2017 GTPP
The stock performance pack 275/40zr19 tires are 27.7” in diameter . You’ll be fine with 28”.
EFI
Masshole central
5.Br0
Why not the 26 to lower the gearing? Especially with the tall gearing of the 2018+ Manual.
For drag tires, it's much preferred to have taller sidewalls.
For corner carving, a shorter stiffer sidewall works much better.
So it's really based on use, and it seems OP is into drag racing.
Grintch
Hunstville
2015 GT PP
But all the drag guys seem to say you need a 4.09 or bigger gear with the tall 2018+ gearing. Something a shorter tire would help with...
