16Kobra
ThanksJust google mustang rear seat delete and you will see several come up.
I found kits from Watson, Anderson composites, Alterum and Shrader easily enough.
Pretty good deal. Just the RSD fiberboard is like $1500 msrpRSD is once again listed at FR, now with a new part number, M-6346612-GT. Some minor changes to the kit along with the inclusion of a new parcel shelf, something that was not included in previous kits. Price isn't far off from the old kit either, last offered a few years ago.
https://performanceparts.ford.com/part/M-6346612-GT
Funny that it says, āOff Road Use Only!āRSD is once again listed at FR, now with a new part number, M-6346612-GT. Some minor changes to the kit along with the inclusion of a new parcel shelf, something that was not included in previous kits. Price isn't far off from the old kit either, last offered a few years ago.
It does not need to be replaced.My neighbor is installing rear seats in his GT500 CFTP and the question came up about the rear parcel shelf, and whether it needs to be replaced when changing the RSD out? Any help would be appreciated.
It doesn't have to be changed but you will have to cut the original for the rear seat latchās. And you will only have car seat anchor holes on passenger side.My neighbor is installing rear seats in his GT500 CFTP and the question came up about the rear parcel shelf, and whether it needs to be replaced when changing the RSD out? Any help would be appreciated.
If you donāt need/care about baby seats does that matter? Will it still have rear seat belts?It doesn't have to be changed but you will have to cut the original for the rear seat latchās. And you will only have car seat anchor holes on passenger side.
I added rear seats in my ā21 CFTP and changed out the rear shelf and did not have to cut or hack up the original
Your right dont matter. Except you will be cutting into the OEM piece.If you donāt need/care about baby seats does that matter? Will it still have rear seat belts?
-J
Your installing seat belts? Best i remember 3 bolts held the seat belts in. To access the top on closet to the headliner trim you might need a knuckle. It made it much easierCan someone help clarify the seatbelt hardware? Iām in the process of installing the rear seat delete and the seat belts donāt seem to screw into the frame, they appear to have a nut and bolt for the top portion of the seatbelt bracket. Is that correct? Thanks.
If installing watch this video. It helped me out.Can someone help clarify the seatbelt hardware? Iām in the process of installing the rear seat delete and the seat belts donāt seem to screw into the frame, they appear to have a nut and bolt for the top portion of the seatbelt bracket. Is that correct? Thanks.
