2019 Mustang GT Stuck Spark Plug
Punchingclowns
Katy TX
Scott
2015 F-150 2018 Explorer
My plugs have a little over 5000 miles, some of that is the break in from the RPG engine and it has a ProCharger.
I figured I would toss in some new plugs.
To my surprise , Number 3 won't budge. The one with the old style plug wire from the coil pack. I haven't went nuts with pressure but I put more on it than I ever have.
Using a plug socket a 6 inch ext and a 2 inch ext. Having to with the tight turn.
Any advice?
BluePonyGT
Seattle, WA
Corey
2017 Grabber Blue GT Premium 6MT
This is why some folks put a tiny bit of anti-seize on the threads of their plugs. It happens from time to time, but usually it's just your angle of attack on some of these plugs. A wobble fitting, or elbow fitting, plus a random combination of extensions can often give you the leverage you need. However, you do NOT want to break it.
First, I don' t know if anyone else have done this, but I try to remove/replace plugs when the engine is marginally hot for just this reason. I know toasting your hands and wrists sucks, but that may be the way to get tough plugs out before the metal contracts as it cools.
Finally, as a last resort I would shoot a tiny (and I mean TINY) bit of liquid wrench in there with the engine cold and let it sit for a bit. Then I'd use a blue paper shop towel, and an extension, and jam it in there to dry things off. Then try it. Don't get impatient.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Tapered seat plugs are also easily over torqued in aluminum cylinder heads. Follow advice above.
