NGOT8R
I went to the drag strip last Thursday and noticed my car begin to act up, in that it was hard to start, just like it was before I installed the Deatschwerks inline check valve. I made three passes on motor that night and the mph was still on point in the 1/4 @ 116.71. On the drive home I noticed the car was jumpy or like it would mis briefly while holding the throttle steady.
Fast forward to today, I noticed a strong odor of fuel when I cycled the ignition switch (but didnāt start the car). I looked underneath the car on the driverās side and noticed a small puddle of fuel on the ground. My first thought was that it must be one of the fittings that I crimped onto the fuel line when installing the check valve, so I cycled the ignition again to prime the fuel line, while looking at the check valve and itās fittings. I saw a mist of fuel and the sound of air as the line pressurized and then depressurized. Further investigation under ample light revealed the leak was coming from the fuel line itself in the area indicated by the red arrow in the photo.
Needless to say, I am perplexed as to how this could even happen, as the work that I did to install the check valve was several inches away from the source of the leak. This got me to thinking back to an anomaly that occurred couple of weeks prior. I noticed that when cycling the ignition switch during priming only, I saw the fuel pressure on my nitrous controller exceed 100 psi. However, once I started the car, the pressure immediately settled to 80.3 psi (which is normal).
Is it possible that the fuel line ruptured due to the excessive pressure that I mentioned during priming only? I only noticed this a couple of times within the last two weeks, when I had the nitrous controller on which shows fuel pressure. I donāt generally keep the controller powered up, so who knowās how many times the pressure has built up that high and gone unnoticed.
Iām still trying to come up with a plan of attack that might allow me to make the repair without having to remove the driveshaft, exhaust and cradle, so that I can lower the fuel tank, SMH. If thereās anyone here that has experienced this issue and can provide insight as to how the repair was approached, I would love to hear from you. Thanks.
