Chris Barnes
Those baers are surely better than the factory brembos. Factory calipers aren't like the typical race brembos you would buy. Not saying they are bad, just "middle of the road" . A real set of brembos and rotors is the same or more than the whole performance package cost.Why would you notice a difference? The pressure coming from the master isn't changing, and the rotor size isn't changing. I HIGHLY doubt baers are better than brembos.
However, it's your car.
The size(s) of the pistons in those calipers may well be different. Meaning a different amount of force clamping the pads against the rotors for a given amount of pedal force/brake line pressure. If this happens by different amounts, front vs rear, the brake balance will shift as well.Why would you notice a difference? The pressure coming from the master isn't changing, and the rotor size isn't changing. I HIGHLY doubt baers are better than brembos.
That may have been a good option, but I wanted to make sure it was a balanced setup and looked good. Does anyone know if the front PP Brembo caliper is the same as the GT350 front Brembo caliper? I know there are different levels of the Brembo's, so was curious if there was a difference? If they are the same, Adding the GT350 rears might be a fantastic upgrade to the factory PP Brakes.I would have saved that cash and just upgraded the front rotors to the Baer and gone with the GT350 Brembos in the rear.
The GT350 brake setup front and rear is a huge improvement alone compared to GTPP setup.
They are different. GT350 uses a different Brembo caliper which was designed specifically for the Shelby. It also uses a 15.5” 2pc rotor as well. The rear 2pc rotors almost share the same diameter as the GTPP fronts, def a huge upgrade.That may have been a good option, but I wanted to make sure it was a balanced setup and looked good. Does anyone know if the front PP Brembo caliper is the same as the GT350 front Brembo caliper? I know there are different levels of the Brembo's, so was curious if there was a difference? If they are the same, Adding the GT350 rears might be a fantastic upgrade to the factory PP Brakes.
