2018 Active Exhaust Components
FISHTAIL
Laplata MD
2018 GT Premium PP
Hey guys,
Looking to grab a pair of actuators, and the pigtail harnesses that come off of each to the main harness on the car. I have a 2018 GT w/o active, but have a full active catback from someone that upgraded, so I just need the actuator motors, and the harness to get mine fitted, then programmed.
I know you can get the actuators as part of the muffler, but that's more than I need. I only need the motor. Are they available separately yet? Is it the same part as the GT350 active? And if so, is that actuator available?
LevittownFordParts
Worldwide
Benny & Mitch
S550's!
The actuators on the 2018's are not available separately from the mufflers. I had heard someone was trying to retrofit the GT350 ones but I am not sure of the out come.
Let me know if you have any other questions,
Benny
FISHTAIL
FISHTAIL
Laplata MD
2018 GT Premium PP
What about the harness? Do you have the part number for the 350 actuators? My local dealer found the part for the standard ones even though they aren't available for purchase, I'm curious if they cross reference.
LevittownFordParts
Worldwide
Benny & Mitch
S550's!
The wiring appears to be serviced in 3 parts. L/R jumpers for each muffler then one main harness, Here are the numbers
JR3Z-14A411-H x2
JR3Z-14A411-J x1
The GT350 actuator number is FR3Z-5K245-A
Benny
jacknifetoaswan
Charleston, SC
JR3Z-14A411-H x2
JR3Z-14A411-J x1
Benny
Benny -
Do you have a price on the jumpers (JR3Z-14A411-H)? It's not showing on the website.
JR
FISHTAIL
FISHTAIL
Laplata MD
2018 GT Premium PP
Awesome, thanks. Now I just have to find some actuators. The gt part number is: Jr3z-5k245-b, but showing backorder.
Not sure if that cross references with the gt350 part. It'd be nice if it did, or if they at least worked the same.
LevittownFordParts
Worldwide
Benny & Mitch
S550's!
No problem thanks for the number. This comes up as a valve repair kit so it was intentionally created to service these valves, I have no idea what it includes and its not priced yet.
-Benny
jacknifetoaswan
Charleston, SC
FISHTAIL
FISHTAIL
Laplata MD
2018 GT Premium PP
-Benny
Figures.
Would you be able to tell me if I need all 3 of those harnesses or just two of them? I'm guessing I need all 3, which is fine, and unless we can say for sure I don't I'll probably order all 3 too just to be on the safe side. I have an 18GT 401a car, so I *should* have a blanked connector under the car already. Just need to go from there to the mufflers.
I'm out of town for work, but when I get back I'll be ordering those 3 things immediately to start.
LevittownFordParts
Worldwide
Benny & Mitch
S550's!
Figures.
Assuming your adding this to a vehicle that never had it you'll need all 3. Is there another discussion your following in which this has been done already?
-Benny
FISHTAIL
FISHTAIL
Laplata MD
2018 GT Premium PP
-Benny
Yes, though with a custom made harness. You were the first to find us the part number for the factory plugs. Apparently some 18gts are prewired, and just need these harnesses and the exhaust, plus an IDS update to add active. Jury is still out on which cars have it and which don't, but it appears to be a premium vs base GT thing at this point.
LevittownFordParts
Worldwide
Benny & Mitch
S550's!
Gotcha and thank you for the info. I assume you are planning to use aftermarket mufflers designed for 2018's with active exhaust?
-Benny
FISHTAIL
FISHTAIL
Laplata MD
2018 GT Premium PP
-Benny
Yes eventually, though I want to make sure it works before I spend that much. I have access to a set of take offs, but they are missing all the electronics. So if I can get the parts, then show it works, I'll be pretty happy.
SMUAlien
Carlsbad, CA
Is JR3Z-14A411-J the main harness that comes from the PCM for those of us with 18's that don't have the blank under the car? When I look up that number it says it's a "jumper" although slightly more expensive than the -H part.
So theoretically I should be able to buy the 3 harness's listed above, the muffler/pipe assembly's that have the actuators in them, use FORSCAN and I boom, I'm rockin active exhaust on my 2018 GT? If that's the case, it's pretty rad.
