2016 GTPP Clutch Recommendations.
FastTR03
Cobra
So the time has come to replace the clutch on my 2016 GTPP. Im at 130k miles and surprisingly still on the stock original clutch. The car sees track about one or twice a year and its also daily driven. Currently no engine upgrades apart from exhaust but plan to eventually install the LTs, CAI and a tune.
I thought I had made my mind up on the Exedy Mach 500 and their lightweight flywheel but then someone recommended going Twin disk and now Im undecided. Wouldn't a twin be overkill for my use?
Also, what else should I change while Im at it? Pilot bearing, Braided line, and slave cylinder?
stannypack
NOVA
2022 Mustang GT
OEM TOB/Slave Cylinder (JR3Z-7A508-A) and Roller Pilot (M-7600-C)
LethalSteveG
South Florida
2018 Saleen Yellow Label
If you are looking to keep it single disc as hey are now, the Exedy Mach 500 is a good step over stock. Other options that will be close would be the Super Street Pro from Mcleod, The Street Warior from us, or the RAM Powergrip.
if you want to upgrade to a twin disc which wil have a softer pedal feel, the Mcleod RXT, Lethal LPX, RAM HD, or the Vengeance Stage 1 is more than enough.
If we can help, please let us know.
https://www.lethalperformance.com/s...17-ford-mustang-gt/transmission/clutch-kits-1
Unbridled5.0
NTX
2022 5.0 N/A, 2004 Mach 1 SC'd
flywheel bolts
upper clutch fluid line
trans fluid
brake/clutch fluid
This would also be the perfect opportunity to install a shifter if you haven't already.
MyStang
Michigan
2015 GT
Exedy ET05SRFD - 2011-17 Mustang 5.0L Organic 23 Teeth 8 Bolt Twin Disc Clutch.
Comes with new flywheel
Couldn’t be happier!
