2015-2017 Headlight
JCFoster
Hornbeck, La
2016 GT Vert, 3.15, A6, Magnetic
I'd contact your local body shops, they have databases to get used parts off wrecked cars and should be able to you one for a lot less.
I'm sure your aware, but if not stay away from after market junk.
sldghmr
MD
2015 GT PP, 2020 GT PP2, 2016 F-150 XLT
Checked w/racing buddy... not a good idea. Even with the cover, I might get gigged for busted headlight....I did find them on Rockauto.com for $760...save you a little bit.
gamecoc430
South Carolina
2017 Mustang GT Premium
I believe it's a sealed unit from Ford. To take off just the clear lens usually requires baking the entire assembly in the oven to loosen the glue then slowly, and carefully, getting the lens to separate from the housing. That's why Ford (and several other mtgs, i.e. BMW) don't sell replacement lens. Good luck!
thehunterooo
2006 Corvette
Used on eBay would be the best option unless you want new which will prob be double in price.
tjkelly212
tjkelly212
2015 GT Premium PP
All the ones on eBay are damaged. But I'll keep looking.
Rock Auto might be my best bet.
Thanks.
HeelToeHero
Ontario
17 GT PP, 23 Elantra n-line
Thanks.
The first only has damage elsewhere and the lens seems ok. Swap it over per your original plan. There is instructions on the diy section on how to remove the lens.
TDC
Long Island
2016 GT350, 2019 Challenger Scat Pack Widebody, 2019 Corvette Grand Sport
For a headlight mod project I didn't want to modify my factory buckets so I bought used on eBay. Took them apart by repeatedly applying heat. After the mod was done sealed them back together. If you can find a cheap used one with a decent lens you could do the same if you're handy.
Gurjit
B.C. Canada
2016 GT Premium performance pack
I'm selling a pair for 1500 Canadian
nothing wrong with the headlights, all mounting tabs and stuff are good
unfortunately I'm all the way up in the west coast of Canada
abie915
Kansas City
'15 GT PP, '16 EB PP
Try car-part.com. They're a search engine for wrecking yards. You should be able to find a used headlight on there for about the price of your deductible, with the added benefit of not having a claim reported on your car's carfax.
69mach1-395
central nm, usa
2016 RR GT/CS
And when you have fixed it, coat both with expel or other clear material for prevention.
