TheLion
Ok, so I messaged FP reps and here's the low down for anyone that NLS stutter has been bugging me for months now (if you don't already know): NLS engages with 80% or more throttle, above 5000 RPM AND when you depress the clutch. I've been thinking all along that it was based on throttle and I've been lifting my pedal foot while leaving my clutch foot on the pedal. I must be pre-loading it just enough. So just slightly lift your pedal foot and make it a habbit and you should be good to go. Also, in rare cases your pedal sensor plunger may need to be slightly adjusted. Many of them have "ratchet" teeth and if you push them down past their stopping point it will set the plunger travel lower. Assuming it doesn't affect the fully depressed state, you could "ratchet" the sensor fully extended position to allow you to slightly pre-load the clutch without engaging NLS which I personally am not interested in as I'm not into drag.
