2015-17 Mustang GT Ford Performance Power Packs
Discussion in 'V8 5.0L Engine / Mods: Bolt-ons, Exhaust, Tuning' started by BobbyGT, Jul 27, 2016.
  1. Humphammer
    Humphammer Well-Known Member
    Vehicle(s):
    Kona Blue 2015 Limited Edition 50th Year
    Jul 1, 2015
    Morristown Tennessee
    89
    Well you are probably correct, but it's not completely open....The honeycomb is still there I just opened up a few more of the holes in the honeycomb that are right in front of the intake snorkel. You would have to get right up close to the grill and be looking for it to tell anything was different. Nothing bigger than an insect is going through them. I also have a JLT filter condom (picture on page 295) that keeps debris from getting into the filter pleats. It is also treated to shed water as well. If bugs and pebbles get into the intake they will fall to the bottom and a good blast from the top with my leaf blower will blow them right back out the snorkel.
    On the positive side something has made my intake air temperature go down. I drove from my home today to Knoxville which is a 65 mile one way trip. On the interstate all the way down and back my intake temperature never got above 4 degrees more that the outside temperature (and actually stayed at 3 most of the time) until I got into stop and go traffic in Knoxville. The outside temp was 73 degrees on the way down and 84 on the way back home. I have checked this many many times on this exact same trip when I was all stock and it never got below 7 degrees more that the outside temp. I don't know for sure how much if any the opening up of the holes in the grill had to do with it because I didn't test it enough to be sure. Can't speak for anyone else but my car at least has lower intake air temps with the new set-up.
  2. Aras
    Aras Well-Known Member
    Vehicle(s):
    2016 Mustang GT Premium PP
    Sep 20, 2016
    Lake Forest, CA
    73
    I see. What is the point of no lift shifting?
  3. Freedom
    Freedom Well-Known Member
    First Name:
    Vehicle(s):
    '16 GT White
    Feb 18, 2016
    California
    972
    275
    0   0   0
    Bang gears without letting off throttle for max accel.
  4. Meatball
    Meatball Well-Known Member
    Vehicle(s):
    17 GT
    Apr 21, 2018
    CA
    177
    85
    0   0   0
    Sweet. I think the Coyote is nicely over-engineered...I'm not surprised you had no reliability issues even with letting it stretch its legs a bit. I'm just trying to figure out what's "normal" with the power packs in terms of the off-idle ping, which I think is as Ford expected and what they tell us not to worry about. I've revved it out at WOT (open window, accelerating next to a wall) and heard no ping. Sounded awesome, actually. But like someone else mentioned, just off-idle, with a bit of a load (AC on, hot out, maybe with passengers), there are a couple of pings just for a moment then the car accelerates strongly with no ping. Is that your experience also? You need a car or wall next to you to hear it. I'm on 91 so it may not happen with 93...
    Just to tell my experience with PP3: It's awesome, but as people have said, it's really only for the (high speed) track. I'm never going to go to the track, I just like knowing I have 472 under the hood and how the power just keeps getting progressively stronger to and above 7K. I don't regret getting it. But in terms of how the car feels, the torque swells with the stock calibration & manifold is more interesting around town. Stabbing the gas in 2nd at 3K up to 6 is more fun because the power surges in there. Sounds like PP2 is like that only much moreso. PP3 just grows linearly, but is fun if you're willing to rev the hell out of it. I have a feeling the 12-13 Boss 302 is like PP3...linear power but less torquey (and less peak torque: 380 vs 390 lb-ft) than the Gen 1 Coyote and much less than Gen2 w/ PP2.
    Eljay52 likes this.
  5. ChosenJuan
    ChosenJuan Well-Known Member
    Vehicle(s):
    2017 Mustang GT PP
    Feb 7, 2018
    US
    66
    Just ordered the PP2 from LMR, should get here early next week. Any tips/tricks for the install? Did you guys drill a hole like in the video? Hoping it won't be longer than an hour or two.
  6. Braski
    Braski Well-Known Member
    Vehicle(s):
    Traded 2015 Blk GT Prem PP on 2019 Corvette GS 2LT M7
    Feb 4, 2015
    Lancaster, PA
    2,082
    934
    Garage Profiles:
    Rating:
    100%
    2   0   0
    Your foot doesn't lift but the computer does. I personally see no benefit from it.
  7. Humphammer
    Vehicle(s):
    Jul 1, 2015
    89
    If you are reasonably handy with some simple tools it's a pretty simple quick install. My suggestion is to remove the filter from the intake before trying the install and also install the snorkel into the factory grill opening first, and then snap it into place on the intake.....was much easier to make sure it was all in the right place. I was on the road feeling the new power in two hours from start to finish.
  8. phatsesh
    phatsesh Well-Known Member
    Vehicle(s):
    '17 convertible GT
    Dec 28, 2016
    SoCal
    122
    Pneumatic ratchet will go along way for removing that stupid both on the firewall
  9. ChosenJuan
    Vehicle(s):
    2017 Mustang GT PP
    Feb 7, 2018
    US
    66
    Finally installed the PP2 today, man I gotta say the torque is great, and throttle response is much better too. Lost an 8mm somewhere in the engine bay so it's either rattling around there right now or fell off while driving haha. I didn't configure anything in the ProCal settings, but the car is stock otherwise so I should be okay with differential + tire size and other settings, right?
  10. Humphammer
    Vehicle(s):
    Jul 1, 2015
    89
    I didn't change anything with mine, and it is spot on. I have no pings, surges, or anything other than a little more gitty-up and a nice moan from the exhaust from 3,500 rpm's and up.
  11. ChosenJuan
    Vehicle(s):
    2017 Mustang GT PP
    Feb 7, 2018
    US
    66
    Did you guys notice more pops/crackles/burbles in the exhaust with the PP2? Mainly with decel
  12. 2morrow
    2morrow DesignR/DriveR/RiceEatR
    First Name:
    Todd
    Vehicle(s):
    '16 Mustang GTPP
    Nov 15, 2015
    415/707/925/530/916
    4,710
    3,277
    0   0   0
    Yup
  13. poncho@home
    [email protected] GettingOld
    Vehicle(s):
    2017 Mustang GT Premium
    Sep 19, 2017
    Laval, QC
    579
    186
    0   0   0
    Even with PP1 there is more gurgles
  14. Rich of So Cal
    Rich of So Cal Well-Known Member
    First Name:
    Rich
    Vehicle(s):
    2015 GT Prem/auto - triple yellow convert
    Jun 19, 2015
    So Cal-IE
    652
    210
    0   0   0
    Oh yes, and it sounds great with my Solo Performance catbacks! :headbang:
  15. tukn20s
    tukn20s Well-Known Member
    Vehicle(s):
    2017 Mustang GT Premium Performance Package
    Jun 19, 2017
    Los Angeles
    99
    39
    0   0   0
    Yes, sounds great with my corsa sport catback.
Loading...
Share This Page
