'18 Sync/Touchscreen went black
Zathras
'18 GT Premium, 400A with navigation. Started the car this morning and the center display/touchscreen stayed black. Was working fine yesterday (and for the 8 months I've had the car.) Tried stopping/restarting the car a couple of times, hoping it would spring back to life, but nothing.
However, I do notice the following details about what functions still work/don't work:
When I shift into reverse, the rearview camera display works as normal, including the graphics. So the physical screen is still capable of showing an image; it just seems to be the Sync interface/screens that are dead. Also, the steering wheel audio volume buttons work, but not the mute or tuner buttons. The "manual" HVAC controls still work. Voice commands don't work. I'm on the original Sync 3 version the car was delivered with, in May '18. (Everything worked so I saw no need to update it.)
Is there a handy way to reset this? The Master Reset procedure I found online cleverly requires the system to be working in order to access that command. Haven't had time to try the old disconnect/reconnect battery, and I'd prefer not to lose all the settings I have in memory...
ODucksFan
California
2018 Mustang GT PP1
If you don't want to lose settings, the only option you have is pulling the fuse that eliminates power to your apim.
Zathras
Zathras
Well, this afternoon it came back to life like nothing happened. Maybe it just locked up really bad and needed some time to sort things out...
louierg
Louisiana
Louie
2015 50th Anniversary Limited Edition #1897
Some how mine did same. Shut down. Restarted and had screen.
See attached TSB 19-7007:
